Youngie1337
Howdy again
been having a slight issue with my useless GT210 (not been using rig for anything other than programming, so not needed to upgrade yet).
Whenever I power on my PC I get a flash of the POST, BIOS INFO etc... but it flashes once or twice and then monitor stays green (button) as if it has information, but nothing is displayed. Removing the cable & inserting again confirms it's booted into Windows, but then the display disappears again.
I have to restart about 3 times before it works, and it has nothing to do with the lead. I've tried reseating the card, changing the PCI priority (so it uses PCI as primary display first), still same problem.
Bit confused as to what it could be considering it does work after 3 restarts, and works flawlessly when it decides to show the image. I've tried VGA & DVI, they're both the same & the problem still exists.
The GT210 doesn't require any power source other than through standard PCI connection.
Specs:
Sabertooth P67
2500K @ 4.4GHz - Noctua D14
2TB HDD
HyperX 8GB 16xxx
750W OCZ PSU Fatal1ty
NVIDIA GT210
Any ideas?
Thanks a lot
Specs:
Sabertooth P67
2TB HDD
HyperX 8GB 16xxx
NVIDIA GT210
Any ideas?
Thanks a lot
