Intel P6100 vs Intel i3 330M
FederaL
Will there be a big difference in gaming between those two processors ? I'm buying a new laptop with a HD5470 and 4Gb of RAM.
So there are 2 laptops with the same specs, looks and manufacter, basically all the same but the difference is the processor.
I know that the P6100 will be sufficient for HD videos, but when I game, will there be a big difference ?
The difference in price is 100 pounds, is it worth it ?
Thank you.
Looking on CPU Passmark, the P6100 has a score of 1518, the i3-330M a score of 1962.
So I'm sure it will give you a fair bit more performance. I would go for the 330M, its difficult to judge how big a difference there will be during gaming, but there will be a difference.
So is it worth it the 100 pounds that the 330m adds ?
If you could stretch another £20 you could get an i5 My link
or here is the link to the whole page of them.
Hope this helps
Hope this helps
I want a desktop replacement, so a 17" laptop. Anyways, I live in Switzerland, so I can't buy your i5
I saw a comparison between the P6100 and the 330M and the only difference was the HyperThreading.
So I'm gonna go with the P6100.
