well its been a while since i updated this thread
ive not really done much to this due to being so busy for the most part of last year but now i seem to have a bit more time to hand to get a bit more done.
changed the design of the front part a bit to allow for the use of 120mm fan instead of the 80mm ones
losing the drive bays and switch area from the computer part has created some much more room
i also sorted out a better motherboard mount which looks better than the mdf underneath
testing it with LEDs
i spent quite a bit of time trying to work out what i was going to do about an easy to access USB port and also what i was going to do with my fan controller and power and rest switches.
i had also spent a fair amount of time at the start of project thinking about what i could do with this space at the back, i then had a plan to use this space to solve the above issue and also do something with what other wise would have been a bit of useless space
so i then sat down one weekend and started to think about how i could lay it out. i came up with this idea after about the 3rd time of trying
i found some scrap mdf that was lying around and thought i would make a quick version to get an idea of how it would/work
i then had some bits turn up today and thought i would cut out the parts to get a better of how it would look
i also tried to get some more mdf to make a better version taking more time over it, the first time i went to the store there was no 9mm mdf in stock and i did not want to use anything bigger (9mm is a bit much really and its not holding any weight) and then the second time i went there i had to wait for them to get the mdf from out the back as they had not put it on the shelf yet but once id got it i the went to the checkout and the line of people was like 15 deep (one checkout open) with the women on the checkout seeming to have all day to serve these people i got bored and a little angry after 10 mins of waiting and walked out but by this time it was to late to go anywhere else so i had two options wait for next week if i had time to go back/some where else to get some or say sod it and just fill it knowing that as long as it was 100% flat it would not matter as it will cover anyway. i went for the later choice as i wanted it done while i had the time and it would id also made a step forward
the end result before primer, if the weather is good tomorrow it will be in primer
