i7 950 + Asus Rampage III Gene + Corsair Vengeance 12GB
General Update,
Right now the systems running stable @;
CPU - 4.021.5mhz 191.4x21
RAM - 766.1mhz [2:8] 9-9-9-24-128-1t
Voltage;
CPU - 1.316v
CPU PLL - 1.799v
QPI/DRAM Core 1.330v
IOH - 1.158v
IOH PCIE - 1.508v
ICH - 1.151v
DRAM Bus - 1.515v
Temperature;
CPU - 47c idle + 77c max load
MB - 25c
ICH - 49c
IOH - 65c
Mezmir thanks for the info on the ram, very intresting read, will have to look into that...
Might have alittle money soon, thinkng of upgrading the cpu cooler im currently using the Corsair Hydro H50-1 High-Performance CPU Watercooler any ideas whats the best to get.
System Specification
- Operating System: Microsoft Windows 7 Home Premium 64-Bit
- Case: Antec Mini-P180 Micro ATX Case
- Power Supply: Antec TruePower Quattro 1000W Modular Power Supply
- CPU: Intel Core i7 950 3.06GHz Overclocked to 4.021.5 MHz
- Motherboard: Asus Rampage III Gene Intel X58
- Cooler: Corsair Hydro H50-1 High-Performance CPU Watercooler
- RAM: Corsair Vengeance 12GB (3x4GB) DDR3 PC3-12800C9 1600MHz Triple Channel Kit
- Hard Drive: Crucial RealSSD C300 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (Boot Drive) and Western Digital VelociRaptor 600GB 10000RPM SATA 6Gb/s 32MB Cache (Storage Drive)
- Graphics Card: x2 HIS ATI Radeon HD 6970 2048MB GDDR5 PCI-Express Graphics Card configured in crossfire
- Sound: 7.1 SupremeFX X-Fi Channel Sound (On-Board)
- Optical Drive: LG GH22NP20 22x DVD±RW IDE ReWriter
- Monitor: Benq FF24IW
- Peripherals: Keyboard-Razer Tarantula + Mouse-Razer Copperhead + Razer Barracuda HP-1
Thanks..
General Update,
Ok guys thanks for all your help, but this is were i am right now.
CPU - 3.211.7.5mhz 133.8.4x24
RAM - 803.3.1mhz [2:12] 9-9-9-24-128-1t
Voltage;
CPU - 1.052v
CPU PLL - 1.799v
QPI/DRAM Core 1.197v
IOH - 1.158v
IOH PCIE - 1.508v
ICH - 1.111v
DRAM Bus - 1.515v
Temperature;
CPU - 38c idle + 53c max load
MB - 28c
ICH - 50c
IOH - 64c
As you can see i have reduced the cpu right back down to stock speeds with ht + speedstep etc. all turned on [back to standard really].
Why you ask, well a few reasons;
1 - No performance change, to be honest the fps benefit against stock speed was nil [due to the HD6970's no doubt], i only use this computer for gaming, and with vsync enable all my games are played at full rez. and maxed out graphics with a constant 59-60 fps, except cysis which never drops below 50 fps.
Im sure i would see massive increases in benchmark scores from using a overclocked cpu through the likes of 3dmark etc. but im just not intrested in that stuff anymore!
2 - Lower temperatures, as i was getting no benefit from the overclocked cpu, what was the point of running the cpu constaintly at higher tempartures, none!
Guys the list goes on........
Ill poberly try lowering the cpu voltage, and all the other voltages in fact to see if i can get those temps down even further.
Thanks again...
