Gurt11
Hello everyone!
To change my activity between modding, I started to try and overclock my i5 2500K. Following Tom's guide, I'll keep you guys up to date on how it's going ^^
CPU: i5 2500K
Mobo: MSI Z77 MPower
Cooler: Noctua NH-D14 ; fans: 2x enermax cluster 120mm
RAM: Corsair Vengeance LP 9-9-9-24-1T 1600mhz 1.35v
PSU: Corsair AX850 (custom sleeved
This is what I'm up to now.
- I set the RAM timings, voltage and speed to the ones specified above.
- EIST is turned off. C1E is disabled. (couldn't find load line calibration or the turbo thingies Tom showed in the video) I think the MSI bios is quite confusing btw.
- When I tested it on stock, the cpu voltage went to 1.232v to support the turbo clock of 3.7ghz. This in mind, I set the voltage to 1.2300v in the BIOS.
When testing, cpu-z is showing 1.208v -> why?
- After the above, I set the frequency to 4.0ghz. That's what it's testing now ^^
Fingers crossed...
updated/
- 4.2ghz at 1.23v (in bios) passed the 30 min OCCT test.
temps: 47-51-52-55
- 4.4ghz at 1.23v (in bios) also passed perfectly. (also disabled 'enhanced turbo' after reading M&P's guide ^^)
temps remained the same.
- 4.6ghz at 1.23v (in bios) gave me a freeze after a minute in windows.
-> upped voltage to 1.25v (in bios), cpu-z now giving me 1.232v ... Curious.
I found the 'vdroop' (which is the same as load line calibration). I left it at auto for the time being. I can only change it in steps from 12,5% to 100%.
This is idle now, ready for testing:
/UPDATE
- Freezes for 4.6ghz at 1.23v, 1.25v, 1.26v.
- Succes! 4.6ghz at 1.27v (in bios) , cpu-z showing 1.248v. (set vdroop/llc to 100%)
Temps were: 52-57-58-60
To be continued...
/UPDATE
Stable overclock of 4.7ghz at 1.31 volts (bios) ; cpu-z showing 1.288v.
temps: 53-60-61-62
/UPDATE
4.8ghz at 1.34v (in bios), cpu-z showing 1.320v.
Temps: 57 - 63 - 64 - 66
/UPDATE
4.9ghz is a fact! Needed 1.38v in BIOS (cpu-z showing 1.35-1.36)
Changed CPUIO voltage from auto to a stable 1.15v too, seemed to help
Let's see if this chip is 5ghz-worthy on air.
CPU: i5 2500K
Fingers crossed...
updated/
temps: 47-51-52-55
/UPDATE
To be continued...
/UPDATE
temps: 53-60-61-62
/UPDATE
/UPDATE
