HTC Sense Calling Problem
KapteinFruit
I got an HTC Sense last weekend and I got a problem. When I use the volume control when I listen to music it also changes the ringtone volume. So if I forget to turn the volume up my ringtone is really quiet. Is there a way to set the ringtone volume so it doesn't change when using the volume control?
you can manually change everything with an app called (audio manager) that way u can set it and leave it... then hope for a update from htc. I own a htc evo and they update often so i hope they fix it soon for u.
