shenlinyan
Banned
Part1:how to convert or edit video for windows?
Part2:how to convert or edit video for mac?
Part1.1:how to convert video for windows?
Read this guide and learn how to rip a DVD to all modern video formats and convert video between any video formats, including AVI, DivX, XviD (*.avi, *.divx, *.div), MPEG-4, H.264 (*.mp4, *.m4v), MPEG-1, MPEG-2 (*.mpeg, *.mpg), DVD (*.ifo, *.vob), Quick Time (*.mov, *.qt), WMV, WMV-HD (*.wmv, *.asf), 3GPP, H.263 (*.3gp, *.3g2, *.3gpp, *.3gp2), Real Video (*.rm, *.rmvb), SWF (*.swf) using AVS Video Converter fromAVS Video Tools
This program has a very simple and intuitive interface. The "learning curve" is near zero. You will start working from the first launch. All you do is enter in the video or DVD to be converted, where you want it to be stored and the location of your CD/DVD Burner or Portable Media Device and the software does the rest. Just follow step by step instructions below:
Step1. Download
AVS Video Converter
For more features about it, you can refer video converter review
Step2. Launch AVS Video Converter
Start > All Programs > AVS Media > AVS Video Tools > AVS Video Converter
Step3. Select Output File Type
Click the To AVI or To DVD or To MP4 or To 3GP or To MOV or To WMV or To RM or To SWF button along the top of the interface.
Step4. Choose Video File or DVD
Click the uppermost Browse button on the right. Navigate to the location where you keep your video files or DVDs, and select the video that you would like to convert. Click Open.
Note: When your input is a DVD Disc, you will need to select the path to your source file: X://Video_TS/Video_TS.IFO. "X" stands for your DVD-ROM or the hard disk drive folder where your DVD is stored.
It is important to select the IFO file, rather than VOB or VRO file, because the IFO file contains the information about the entire DVD structure and this way you will avoid audio and video de-synch problems when converting. Also, most DVDs have several VOB or VRO files (files with actual video) and if you convert VOBs or VROs instead of IFO, you will have to merge them afterwards, which is not the case with the IFO files.Anyway if you have only VRO or VOB files, select them. AVS Video Converter converts these files perfectly too.
Step5. Select the Output Location
Click the bottom Browse button on the right. Choose the location where you would like to save your converted video file. Click Save.
Step6. Select the Output Format Profile
In the list of Profiles select one of the available profiles or click Edit Profile button to manually set the output video profile parameters.
Step7. Convert Video
Click Convert Now and step away from the computer (processor performance will be seriously affected during conversion). If you want to watch the progress while you convert, click the Advanced button until the viewing screen pops out of the bottom.
Part1.2how to edit video for windows?
• Step 1: Download and install AVS Video Editor
• Step 2: Launch AVS Video Editor and load your video
• Step 3: Add your video to the Timeline
"The first is the worst" is not about your primary experiences with AVS Video Editor anymore if before using it to implement your ideas into reality you will rely on the following logical steps thus passing on to the main actions without any delay and issues.
Download AVS Video Editor, run AVSVideoEditor.exe and follow the installation wizard instructions.
Also ,you can get the most information from here: http://www.best-video-editor.com/
Run AVS Video Editor. A new empty project will be created automatically. Press the Import button within the Main Library pane to load the desired video file:
Select your video and press Open:
The selected video file will be added into the Video category of Main brary:
To apply different effects to your video, you should place it to the Timeline area, first of all. So, select your video in the file area (enter the Video category if you are not in it) and without releasing the left mouse button drag it to the very first row of the Timeline and only after that release the button to drop the video there
Now all the preliminary actions are done and you can proceed to add transitions, apply different effects, lay text and other videos over the main ones, dub episodes and create DVDs with menus.
Part 2how to convert or edit video for mac?
Ever though of converting video files downloaded from the Internet or taken by our digital cameras to your iPod, iPhone, Apple TV, PSP, Creative Zen and a lot more mobile players on your Mac machine? Wondershare Video Converter Suite for Mac provides you with the perfect solution. It can convert video to all kinds of formats for all popular players.
If you want to learn more about dvd ripper,you can log in the following site: http://www.topsreviews.com/reviews/dvd-ripper-review.html
It has both a Power PC version and an Intel version, and you can just install the right program depending on your CPU. After the program is installed, you follow the steps below to convert video to all mobile players:
Step 1. Add Video files
Click the Add button, and the program will let you browse your computer hard drive.
Select the video files you want to convert and click OK.
Step 2. Output Settings
After adding video files, you can start to set output settings for each file:
Select an output format from the Format drop-down list. Just select an format according to the player which you want to put your videos on.
Click the Settings button to set encoding settings including video resolution, frame rate, bit rate and video encoder, audio encoding settings including sample rate, channel, bit rate and audio encoder.
Click the Browse button to specify an output folder to save the converted files.
Note 1: If you want to convert all the added files into one format with the same encoding parameters, you can just click the “Apply to All” button.
Note 2: You can check the “Merger into one file” option to convert all the added video files into a single file.
Step 3. Click the Start button to start the conversion
. And all you need to do now is to wait for the conversion to be finished. The remaining time will be shown on conversion window for your reference.
Tip 1. Trim Movie
If you just want to convert a clip from a video file, you can select this file and click the Trim icon to capture a clip from it. In the Trim window, you can trim video length either by dragging the Start Time and End Time sliders or by setting the time parameters in each corresponding field.
Tip 2.Crop Video
If a video file has black video sides around its video, you can click the Crop button to open the Crop window and remove the black video sides. You can specify the video crop area by dragging the crop frame or setting the four crop parameters (Top, Bottom, Left and Right).
Tip 3.Movie Effect
If you want to change the original video effect, you can click the Effect icon to set the video brightness, contrast, saturation, and even audio volume. You can also choose to apply a special effect to your video from the available effects including Gray, Emboss and Negative.
Note: If a converted video has stripe, you can select a Deinterlace mode here and convert the original file again to remove the stripes.
Step1. Download
AVS Video Converter
Tip 1. Trim Movie
Tip 2.Crop Video
Tip 3.Movie Effect
