How to adjust Prey's FoV and disable Motion Blur
So they were simply too lazy to add them to the menus? double the work eh?
Not always the reason. Sometimes the options are still available from development but the game may be setup to always assume a particular FOV and motion blur in which case they wouldn't add it to the menu. If you add it to the config and experience unwanted side effects then that's your fault.
