B BILKO1 New member Aug 16, 2007 #1 I'm using the same as you but i could do with some more vcore and vdimm whats the max 1:1 fsb you can get on your P5B stable enough for benchies?
B BILKO1 New member Aug 16, 2007 #3 I'm off to Maplins whats safe voltage for ballistix pc8500? specs say 2.2v but i'm already on 2.45v:O and they arent warm as they have a delta screamer blowing on them.
L LiViNgL@RgE New member Aug 22, 2007 #5 How much is to much I can't answer that! As long as your cooling is up to the job sky's the limit!
K K404 New member Aug 22, 2007 #6 The current C2D MHz WR was ran at 2.28VCore DO NOT try that without LN2!!!
