maverik-sg1
Guys,
For those who don't know I have a Mach2 sitting on top of my Winchester CPU on a DFI LP SLI-DR MOBO.
Overclock is great: 276x11 @ 1.65v, LDT @ highest voltage (1.5v) and Chipset at 1.8v.
The problem I am tryin to understand is that my temps are -53 on the head with -18 or -20 on the CPU using speedfan 4.21 or as shown in BIOS.
The second I run superpi or 3dmark the temps on the CPU go up as high as +4 degrees in about 2 seconds
I stripped it down thinking condensation but found it war dry as a bone. The Artcic Ceramique was well distributed with a nice square print where the head was seated.
So just to be sure I cleaned the head and re-installed using a thin coating of ceramique on both parts.
Fired it up again and exactly the same problem, the head drops from 53 to 45degrees (after about 15mins).
OK so I know I put a few extra washers on the bolts thinking that would improve the contact, my question is:
To improve Head/CPU contact, should I be adding washers or taking washers away?
Your thoughts.
Cheers
Mav
Your thoughts.
Cheers
Mav
