I've fiddled around a bit with OC'ing my rig, and the temps while running my Q6600 @ 3,4GHz is around 46C idle, and almost up to 67C under full load using OCCT (where the program stops testing at 67C). As it is now, I'm only running my CPU at 3,4GHz while benchmarking, as I think the temps are too high. The same goes for 3,2GHz, only with a few degrees lower coretemps, so usually I'm running at 3,0Ghz, where it's @ 40C idle and 66C full load.
My rig:
MB: Asus P5N-T Deluxe (BIOS 0802)
CPU: Core2Quad Q6600 "G0" @ 3GHz (8x375)
RAM: 2x1GB Cruicial BallistiX PC2 8500 @ 1200MHz
GPU: 2x XFX GF 8800GTS 512 ADEdition 750/1050MHz
Cooler: Tuniq Tower 120
PSU: Antec TruePower Quattro 1000w
Case: Antec P182
I read one of the previous posts regarding the Q6600 withstanding temps up to 70C, but I still think my temps are pretty high using the Tuniq Tower cooler. I've left all the voltage options on auto, as I'm fairly new to OC'ing.
Have any of you got an idea of how to keep my temps down, by for instance setting the vCore manually?
