High temps. with new OC settings?
Juusuhako
Hello all.
Old OC Settings:
4.3GHz (with Turbo Boost enabled)
Voltage: Auto (OCCT Max. Vcore 1.3V)
LLC: 1.650
amp/watt setting: 250 (I dont recall their name)
New Settings:
4.3GHz (Turbo Boost Disabled)
Voltage: 1.23 (OCCT Max. Vcore 1.25V)
LLC: Auto
Load Line Calibration: High
Now I did the "CPU:LINKPACK"-test in OCCT for 30mins without crash. Max. temp. was 66/72/70/66C.
My question is why im getting a 70C temp. on a 1.23V OC (that peaked 1.25V at some point during the test, but wasnt stuck on it). When I ran with voltage set to auto I would hit about 70-75C during an IntelBurnTest, and that was at 1.27-1.3V.
Sometimes the temps would lurk at 50-60C, sometimes 45ish... And then sometimes jump to 65-70C. Does it depend what OCCT is doing to test the CPU? I just figured now that I moved to a set voltage rather than auto I would get much lower temps. Oh, and another thing - I disabled Turbo Boost, but its still downclocking/upclocking all the time, whats up with that?
My CPU cooler is a Corsair H100i with 4 Noctua fans. Im idling at 25-30C, but I did that too with voltage set to Auto.
