Legacy-ZA
The latest release of LatencyMon has apparently fixed them issues, already disabled the startup items I found my latency goes down if the Corsair Link, Geforce experience, Chrome notification software... Although when I start a game the latency goes way up again, all my drivers are up to date... Even tried rolling back some to see if there was change with no luck... as far as I can tell it's specifically to do with the DirectX and Nvidia drivers.
Well, it could be the nVidia driver, but not necessarily, it could be something that runs in conjunction with it that is causing the problem. When you re-installed the driver, did you do a custom installation? If you didn't; Do a clean driver installation, but don't install GeForce Experience and all the rest, just the driver, see if that works.
I see that you use Windows 10, you can try and disable the feature that allows you to take in-game screenshots, do recordings etc, you can find it under the X-Box settings. You will have to use your MS account in order to access those settings though. (Stupid, I know)
Ah yes and erm, if you don't mind, attach a screenshot for us displaying your startup items?
