Things to check :
Any air in the system - shake the case/ tilt in every which way you can while the system is running. Also after you have done this release the res cap a little until the system is fully bled (24hrs should be enough).
Any kinks in the tubing? This can prevent water flow, if you are seeing a fair amount of turbulance in the dual bay res odds are its ok.
Are you using a backplate on the D-tek? If not then you may have warped your motherboard preventing decent contact - backplates are a necessity with screw down blocks.
What rad is it? If its a PA120.3 then it should be fine for a quad, however if its a thin blackIce pro/XSPC then it is not the best for cooling a quad.
Have you got the D-tek orientation right? Sounds funny but you must have the inlet in the centre and the outlet to the corner.
Theres a few things to try before you lose hope. You probably wont notice much difference at idle, full load is where watercooling counts.
Oh and radiator orientation makes didly squat difference once the setup has been bled.
