Help Watercooling Temps Increase :s???
Silentsnake
Good morning everyone (that helps :p)
Well i finally put together my first watercooling loop on my Stacker case yey! and was expecting some amazing temps so that i can OC but not only was i far from good temps, they had also increased over my last cooling heatsink which was the Thermal ULtra 120 extreme
Heres my loop
Res > Pump > Rad > CPU Block
New > used > New> Used
Some Dual Bay Res > Laing Vario pump > TFC Xchanger 120 rad > D-Tek V1 Block
Well my temps went from being on 35'c Oc on ait to them being 43'c on stock watercooled :S??
Any help ideas on how to improve my temps or what may be wrong i would really appreciate it anyones input
thanks all
EDIT: WHAT PARTS ARE NEW AND USED :)
A very simple fix is to take the machine outside and blow all the dust out of the radiator.
Either using your own breath or a can of compressed air. ;)
Should cut the temps down a bit as dust is an insulator.
name='°TheMadDutchDude°' said:
Are your max temps the same or higher, or lower?
The temps above are on idle with abit of Surfing and music
The max temps i have had on stock are about the same or + 5'C but when i had it OC to same settings as when on air temp increase was like + 10-20'c
Also i should of added what parts are new and used My Rad is brand new :(
Not a spec of dust in the rad its brand new
thanks
name='teknokid' said:
My guess is the rad cant cope.. get a bigger rad?
wow :(
does the orientation of the rad matter cos i have it upside down :)?
and how fast the pump is pushing the fluid? i have it on max should i slow it down or is that good :D?
noob questions :P
fast is good....
Erm, Im not sure, But i do think upright is better..
i have the barbs at the top bleed hole at the bottom i was told that this is upside down lool :S
im gnna try stick a fan behind it aswell so a push and pull system hope that helps if not ill change my block to another that i have
if any1 has any ideas or what they would do in my situation please share :worship:
Open the cpu block up, It may be full of gunk :)
Yea i done that :D before i put the loop together was fool of like hair and weird things lool
i might open the bleed hole and see if any air comes out maybe theirs abit stuck
I would get a bigger rad, a Quad under a 240mm rad is a bit of a strain on the rad IMO.
lol, a single can handle a quad :P
But as he rightly said, a dual is more adequate.
Haha I thought that he had a 240mm... Sorry guys I am quite tired.
A Quad on a 120mm rad. is a lot of work.. up it to a 240mm or even 360mm if you want to do the job right :D
