Help On Raid Card
Xellex
I have 2 samsung spinpoint F3's i recently bought to put in Raid 1, hoping they'd work on a 3rd party controller on my motherboard, but that didn't go to plan. I need help to find a reliable controller which is speedy and easily setup. I only plan to spend 50-£100 because i plan to upgrade later on this year. Thanks.
RAID controllers are a very good example of "you get what you pay for". If you only have £100 to spend, then it would be better to stick them on the motherboars's RAID controller. Otherwise, for a decent controller, you are talking a lot more than £100.
