Hey guys, I need your help again!
I know how awesome you are with cases, I would go off Tom's reviews a lot but I am an air cooler myself so large parts of the reviews are quite irrelevant to me (I think).
So here's what I'm looking for:
1) Avoid full towers if possible, it's not the height I need.
2) Must be able to fit a GTX 680
3) Side panel window (more about side panel fans below)
4) Black/Dark coloured
5) No fancy curves or shapes - I like it 'sexy and simple' with sharpish edges. For this reason I don't think most of the NZXT cases suit me.
6) Must be able to accommodate a NH-D14
So I heard a lot of you don't like side panel fans. I've always thought they were a good idea but you know more than me. These are the fans I ahve at my disposal:
Front: 120mm default case fan
Top: 140mm default case fan
Back: 120mm Corsair AF120
Side: 120mm Corsair AF120
I hope that helps
(P.S. I have Red and Blue cold cathodes, using my Blues at the moment)
I hope that helps
