Via boards look good for HTPC purposes, because they have hardware decoding acceleration built in. However, the only software that supports it is a modified mplayer on Linux, and even then it's not clear if it will decode 1080p H.264 okay.
I currently use XBOX Media Centre which is excellent. Plays everything standard definition, boots in under 10 seconds, cheap etc. No HD though, cos it's only a Celery 750...
Has anyone actually managed to build a HTPC with a Via board, that is capable of HDTV/HD-DVD/Blu-Ray playback?
