H100i Temps
ShaunB-91
Hey guys,
Okay so just going through the motions of setting my CPU at stock, it currently sits at 1.0v and is testing through OCCT, I did try lowering under BIOS but wouldn't post. My idle temps are about 27, going through OCCT its a bit below the 60 mark, are these correct figures?
What I don't understand though is whilst testing my rig is idle silent but when an intense game like BF4 is run it gets quite loud from the fans, I've not tested temps in-game yet but surely it doesn't jump that much higher, my CPU is 100% during testing so...
I'm probably missing something but I've never done this before so go easy on me. :D
Your temps look good so no need to worry there, They are fap worthy ^_^
Maybe the fan profiles change once a game launches, Would explain the fan ramp up.
Thats good to know then. :) During OCCT it didn't seem to go above 56, idle is arond 27.
Just been on BF4 and it stayed quite quiet actually. O.o
Odd, Well it must be the fap cave interfering with it somehow :D
To me it just sounds like a fan profile type thingy majiggy.
Haha, the man juice may be clogging it up. ;)
