Essentian
I'm looking at getting a h100, and was wondering what peoples experiences have been like with them. I'm mounting it in a HAF X, so the plan is to keep the top 200mm fan as an exhaust, then the rad + 2x120mm fans inside the case.
Are the stock fans ok, or would you recommend something else?
Thanks
Edit: Also - does the h100 come with all the bolts I'll need to install it? Or will a trip to the local hardware store be necessary?
Thanks
