Gtx 780 sli getting to hot
88scott88
my 780 acx sli r getting very hot when gaming i do have triple screen they r hitting 80-90c is this ok?? here is my rig gallery LINK
The cards are set to run UP to 85c anyways, if you want the temp lower just change it in something like afterburner to aim for a lower temp (70c for example) and the fans will just spin up sooner and the GPU boost 2 wont push the boost overclock so far
if they are set up to run up to 85c is it best i leave them as they r i have not overclocked them at all???
Well you could OC them more, but I dont think you would be too pleased with <85 C temps... So dont, as long as your on air
They overclock them selves. You can change the temp setting if you want them to run cooler. Try reading / watching the reviews.
ok thanks, i have looked in to it but could not find the sli with acx coolers so i just wanted to know if its ok for them to be running at 80-90c for hours on end, i dont mind the temps if they r safe at that.
