Granny's PC: A 'Budget' Build gone horribly wrong!
haha you have picked up on the one thing I forgot! :p a power switch! ill add one to the front that i robbed from the old front of the case. just a quick hole will sort it. been overclocking ;)
managed to get it to wprime @ 3.3ghz on stock volts :O but above that wasnt stable on anything...hmmm, anyways i toned it down to 3ghz for 24/4 use. accorrding to custompc's cpu tests they did a month or two back that makes it just a shade slower in wprime 32m than an E8400 which aint too shabby :D
Idle temps (18/20 degrees c if you cant read it)
Load Temps (32/33 Degrees c if you cant read it)
Haha, nice. :p Could you post up a mini step-by-step? Sorry to be a pain, I'd just like to see the process as I can't many online. :) If it's not too much hassle, if i is, don't bother!
Nice temps btw!
