Rob_the_scot
I want to apologise as I was unsure what section to post this under
My problem is I built a budget pc using i3 and a xfx 6850 on a matx board now the problem is the 6850 covers up every single sata port on the motherboard and I only need 1 bl**dy sata connection.
I'm currently using a right angle sata connection and it fits under the gpu but I'm a bit paranoid in case of long term damage if any.
So I have 3 options
1= order a smaller gpu msi 7770
2= pci express card (x1 slot)
3= my gpu has no warranty now so I suppose I could "mod/cut" a small hole in the plastic shroud on the gpu just enough for 1 sata cable.
what would you guys do??
So I have 3 options
