Hi im planning my first ever water-cooling build and have decided to have just one loop for the cpu and go from there
. Im planning a custom system and after looking at scans selection i have decided on the follwing parts
Thermalright XWB-01 socket 775 block
XSPC 5.25" res inc. pump
Asetek black ice radiator 120mm
TFC 3838 straight hose compression fittings
2M TFC clear tube 3/8 ID 1/2OD
Coollabratory 1L pro-blue coolant
It comes to a total of £100.20 inc vat.
Would this be a good beginner setup for an antec300 case cooling a E2160@3.20GHz?
Are there any other parts that are cheaper and better?
Or is this setup ok to go ahead with?
All of your knowledge is appreciated and hopefully the build will start on 15th june 2009
Thanks
Stevej696
Thanks
Stevej696
