Get rid of Thermal Pad ?
name='Dave' said:
just swallow your pride and go into a shop and buy some nail polish remover. seriously there isnt really anything else. unless you can get some ethanol from somewhere :)
dont some of the companies like arctic silver say not to use ethanol or am i mistaken?
rubbin alcohol is Isopropyl alcohol so its fine ; nail polish remover is Acetone which is also fine (but may discolour some hs bases dependin on imputities added to the remover)
ah yeah fair enough i see thats allright then
