All I can say is that be prepared to reallly take your time with this build and I would highly, highly recommend you take a look at Silverstone's short PSUs with their short power supply cable kits. As that case is very tiny and every bit of space you are really going to need.
I have built my moms PC in that case and I can tell you, even with a short Silverstone PSU and their short cable kit, man... it was tight as a motherf*cker in there and to get everything wried up.
Plus, cooling inside that case is going to be a nightmare, so I highly recommend you taking a second look at a slightly bigger case. Since I personally can't really recommend it, yes it's tiny, but it's cable management, the room for things, it's cooling potential just isn't up there for me to be comfortable to put a gaming system inside.
All my mom does is browsing few pages on the web and mostly doing Photoshop CS6. I put an i7 2600K with an Corsair H80, Gigabyte GTX 960, ASUS P8Z77-I Deluxe, 8GB RAM, 1 SSD and 1 HDD, with PSU in there and it's not enough cooling for it. I can hear the GPU running hard alot.
So in all, I recommend another case, that has slightly better cooling than this and slightly better working space. Hell, it doesn't even have proper feet! So if you don't have like a rubber surface, that thing is going to fly across the space if you just nudge it lol.
