Future rig
Innocent159
Thinking of buying it soon with this spec:
Chassis: Antec-LanBoy Air Red:
Motherboard: Gigabyte Z77-D3H LGA1155
Processor: Intel Core i5-2500K Sandy Bridge
Heatsink: Thermalright HR-02 CPU Cooler
with two fans: Thermalright 120mm 2000RPM
Ram: Corsair DRR3 16gb kit
Graphic card: Gainward Phantom GTX560TI 2GB x2 sli
two SSD: Verbatim 128GB SSD
HDD: Seagate Barracuda 2TB Green HDD
DVD rom: LG 24X SATA DVD Writer
: Asus External Blu-ray Writer
Psu: Corsair HX1050 Power Supply
Case fans: Coolermaster 120mm
Fan controller: Zalman MFC1 Combo Fan Controller x2
Budget: R20 000
What do uc think?
nice rig overall mate but instead of those two 560ti's you could go for a 670 ? same sort of price :D and maybe a spend a little extra on a H100 and that would be balling :)
I think it's pretty terrible.
I'm guessing by the presence of 2 fan controllers, you arent changing your mind about the ridiculous amounts of fans...
Tbh - it's barely even an upgrade from what you've got...
I'm not for the H100 because i never done water cooling and heard its a killer for maintance
Aaa i see but then that had nothing to do with a H100,
and to be honest WC on its one isn't so hard either....
Good luck anyway !
talking about water cooling in general, the H100 doesn't need any maintance but i'm not into it
your not into a simple piece of hardware, but you were wanting to do compressed air cooling?
and i vote this thread closed and have it continue on the other one that is also open for the same discussion
i didn't say i'm going to build the compressed air, it was an idea... i'm investing R20 000 into a system and one water cooling fault can blow it all + with the toddlers in the house i don't think its worth the risk... THREAT CLOSED!!!
