Recon-UK
Banned
Ok guys,
For those of you with a 4xx or 5xx series Nvidia GPU, you may be finding some odd issues where the clocks on the cards do not spool into 3D mode, this is in fact an issue with the 300.xx revision drivers, now it does state under the 304.xx something driver, that this has been taken into account, and has been fixed.
I will recommend you to roll back to the 296.10 WHQL driver, until a new release of these 300.xx drivers are working properly.
This issue is mostly on factory overclocked GPU's.
There is another way around this small but annoying hurdle, bios flash the card to a stock, factory, none OC bios, but this also holds it's many risks.
Just a heads up for you guys posting with low fps and core clock issues.
If it is not the drivers, there is definitely something else wrong.
Thanks for listening.
