Well as phil knows ive been having an annoying condensation problem around the neck on my GT where it joins the head...
(marked by the Red Arrows
Well 4 days ago i decided to try another way of fixing this prob by using a hose clamp because i thought there was a gap in the heat shrink that was causing the condensation to build... at 1st the clamp didnt fix it at all.. in fact it made it worse because i think the small gaps in it caused condensation even more... So i thought why not stick some seal string inside the clamp b4 i put it on and hopefully that will sotp any air gaps..
I was right !!! 4 days later and not 1 drop of water to be seen anywhere
