Asperatis
Hi all!
So Nyssa's been running for about a week now, and I wanted to start doing some overclocking.
Some specs:
5930K
Rampage V Extreme
32GB Corsair DDR4 2666
2x Tx
custom water loop
Obviously I started playing around with the cpu.
At first I wanted to see how high I could get it to go to have an idea of what kind of chip I got. The method I used was adjust the multiplier and the core voltage. If it booted, I ran aida64 stress test for 5 minutes (just a quick validation, not looking for a 24/7 clock anyway)
These are the results I got so far:
1) 4.5GHz @ 1.3V, passed the 5 minutes test
2) 4.5GHZ @ 1.274V, passed the 5 minutes test
3) 4.6GHZ @1.274V, booted into windows but soon failed the test
4) 4.6GHz @ 1.289V, booted but failed the test
5) 4.6GHz @ 1.299V, same thing, booted but did not pass
6) 4.6GHz @ 1.323V, passed the 5 minutes test
7) 4.7GHz @ 1.402V, booted but did not pass
8) 4.7GHz @ 1.422V, booted but did not pass
9) 4.7GHz @ 1.442V, booted but did not pass
I did not want to go much higher in voltage, as I'm not sure what the safe limits of the Haswell-e processor range is, even if they're under water.
Next up I searched for a 24/7 clock, which I wanted to set at 4GHz.
For now I got the following results:
10) 4.0GHz @ 1.076V, passed the 5 minutes test, even ran for about 30 minutes too. Will ran this one overnight to see if she passes.
Any thoughts on my progress so far?
How am I doing, suggestions for improvements, hints and tips, anything is welcome
Cheers,
Asper
Some specs:
5930K
Rampage V Extreme
2x Tx
custom water loop
Cheers,
Asper
