First leak test
corban
So with some help and lots of reading and more patience than im used to using i have done my first leak test.
My link
More will follow as i attempt to vlog my first watercooling experience and stumble my way thru it all with lots of help from people
Looks good, you don't have to worry to much with the leak checking using compression fittings but better safe than sorry
Yeah im just following the safest route i can for now, ill leave it a couple more hours i think just to be sure. Thanks again Seib how is yours coming along ?
I'm not doing anything to mine for a week or two, I need to sort a few personal things out and then get some money together before I start.
I have most of my watercooling stuff already though, just need to get a few other bits and bobs.
Nice and tidy
I think the front of the res goes nice with the case, it doesn't look out of place anyway. Using a DVD drive is frowned upon round these parts though, but we will let you off
For a fan controller check out the NZXT Sentry Mesh or the NZXT Sentry Mix, I ordered a Sentry Mix today. They have 50w per channel which is good because you can run up to 4 fans off of each channel. The Mesh is god as well though but it only has 35w per channel and no LEDs, which the Mix does have.
Sentry Mix
Sentry Mesh
Thanks for the comments and suggestions guys, overall im really pleased with how its come out and ill be totally honest i wanted bitspower fittings but couldnt afford them , however having used these ek ones and seen how they look and fit with my case i am really glad i got them they have worked just how i wanted them too and when i get some more cash together id like some angled ones too.
The NZXT fan controllers do look quite nice and the one that i could make a purple colour to match the mayhems fluid is the one i have my eye on !
Generally im a huge fan of corsair products so will definately look into them i had the pleasure of needing to rma my psu with corsair and they were amazing to deal with cannot reccomed them enough!.
