Finding ICs
Ham
As many of you know i managed to blow up a chip on a 7800GT. For those of you who don't..i did. and it wasn't the GPU.
Looks like leadtak arn't very interested in repairing it, so does anyone know where i can get Specific ICs, information on those ICs, possibly diagrams of the card and somewhere i can buy them?
do you have the name of the ic or is it completly destroyed ?
usually its often easy to find information about a specific ic through google and stores can sometimes be found in the yellow pages.
Well on the leadtek board it was 475 then somthing that was totaly burned. Looked like an R
And on my XFX one its D56D then 12 perpendicular to it.
The 7800GT IC referance is Q502
I've tryed google to no avail. If you find something i missed by all means correct me.
where is the chip located on the card ?
which form does the ic have ?
and how many legs does it have ?
Its a small 6 pin IC. I think its a voltage controler, possibly a darlington pair. Its at teh back of the card above the PCE-E connector.
What do you mean when you say form?
an ic is usually square or rectangular and can have legs on 1 2 or 4 sides.
dont think i have ever seen one with legs on only 3 sides.
i saw an image of the broken ic in another thread and i can do something constructive.
i will not do it now, way to tired and its half a day past bedtime but when i have gotten some sleep i will rip out my card and take a look.
sitting with a leadtek 7800gt and the ic isnt covered by the heatsink so should be an easy check :)
If youve got a leadtek one go for it. But my XFX one has a different chip on it, that does the same thing.
farnell electronics
rapid electronics
rs electronics
all have huge stocks of chips if u can get the chip number off ic or get another card to read the chup number off of if its only v reg or transistor pack they wuill prob be able to get you one then it shouldnt be hard to fix
okey im up and awake and found out the computer didnt work so good with no monitor hooked up :rolleyes:
but here is what i found.
i might have gotten the 16 upside down.
http://www.digchip.com/datasheets/parts/sc/parts_sc07.php
SC2128C-D53D : Remote Fan Control ic For Electronic Fan Application
just for the record, using ravens info, i have done some serious number hunting and managed to nail down a manufacturer then got good old google to translate it so i could hunt down the chip on their site:
ok, well cos of the translation i cant link straight to the page :mad: so heres the info they got on the site:
Product type : SC2128C
Product name : And supporting the use of fans SC2268 declassified control circuits
Product overview :
SC2128C is a high-performance fans control Shanpian IC, which includes wind speed, timing, rhythm wind, sleep wind, Baitou and lantern control functions. In addition, SC2128C also provides led shows export sounded export keyboard control of remote control and decryption circuits, and circuit performance is good, the external device small. Guanjiao ranked facilitate Yinzhiban wiring, and a good Xingjiabi.
Main features :
* CMOS工艺 used.
* Low power consumption.
* Alternative independent Lantern control.
* /6 seconds per cycle-90 seconds (3 seconds for the closure of steps) controlled wind patterns
* Remote control with built-in user code declassified circuit.
* Dip or sop packaging (22 Guanjue can not use the sop packaging)
* 3, or 3 or more independent / non-independent Baitou / Lantern export control.
* 16,18,20,22,24 Guanjue packaging can be used to install one or two Baitou / Lantern control.
* Three operating modes : normal mode, rhythm patterns, rhythm sleep patterns.
Should use
* Fans application optimization
* Apply heat fans, cold fans and other household appliances remote, and exporting electricity regularly ping control.
excuse the ??s, googles basic chinese translator is still in Beta stages. Also got a quote on the way from a retailer in the USA
