Finally started my new build
yesterday i was playing with my cpu... i`m testing the overclock ability of my 3770k chip and how much heat it produces. i'm using occt 4.3.2 i was running half an hour tests in limpack mode.
stock:
multi: 35, vcore: auto, vdroop: auto
temps: 42, 41, 40, 38 -> 40.25 average -> 21.45 delta
4.0:
multi: 40, vcore: auto, vdroop: auto
temps: 52, 51, 52, 47 -> 50.50 average -> 30.80 delta
4.0:
multi: 40, vcore: 1.000v, vdroop: 100%
temps: 47, 45, 42, 40 -> 43.75 average -> 23.15 delta
4.2:
multi: 42, vcore: 1.050, vdroop: 100%
temps: 51, 49, 47, 45 -> 48.00 average -> 27.30 delta
4.4:
multi: 44, vcore: 1.100v, vdroop: 100%
temps: 54, 54, 53, 49 -> 52.50 average -> 31.30 delta
4.5:
multi: 45, vcore: 1.150v, vdroop: 100%
temps: 57, 59, 58, 54 -> 57.00 average -> 36.00 delta
4.6:
multi: 46, vcore: 1.175v, vdroop: 100%
temps: 60, 61, 60, 57 -> 59.75 average -> 38.75 delta
4.7:
multi: 47, vcore: 1.225v, vdroop: 100%
temps: 63, 64, 64, 62 -> 63.25 average -> 42.25 delta
will be continuing testing today... :)
edit:
4.6:
multi: 46, vcore: 1.200v, vdroop: 75%
temps: 56, 58, 57, 53 -> 56.00 average -> 37.00 delta
Nice temps , what are you using for a cooler?
You have an amazing chip there mate!
cheers mate i was lucky i guess
:D
Epic Temps dude!
cheers mate happy me
very nice overclock temps...well done
cheers mate
That overclock and the temps look really, really good.
cheers mate... i had so much luck with this rig, it's unreal:)
i'm using a h100i with sp120 pe fans running at low speed
the case has three af120 pe fans pulling air in and one af120, one af140 and the sp120's exhausting air
Very, Very , very nice job!! You put a ton of work into your rig and it looks amazing! I have the Stryker and Mpower on order as of 2 days ago. You have given me plenty of ideas for modding my rig if i choose to do so. Again very well done!!
Very nice job building this Styker rig CPMFW. :D
Thats some real quality modding you got going on through out the project.
cheers mate...
good luck with your project :)
cheers mate...
Happy with the final results? ofcourse you are! that chip is heave if it stays that cool and OC's high with low volts! All that work paid off with a little bit of luck, and you won that lottery :)
just read through the whole log and what you have done and the work that's has gone into it looks amazing. It has given me push to start thinking of ideas of what to do to my stryker case :D
i guess i was lucky :)
Yeah I agree :)
I will try again tonight to see if I can get the same results as you.
Did you make any other changes to it? If you dont mind can you post screenshots of your Over clocking settings please.
Thanks in advance.
P.s new photos would be awesome :)
Your build is amazing. I am loving everything. I usually hate white electronics and such, but looking through you build log is making that color scheme grow on me. You have really done a wonderful job so far. I love how nice everything looks and the cables look perfect. Because of this log I ordered myself some paracord to try and do all my cables, so my PC looks a little better.
Keep up the good work and I can't wait til it is finished.
yes mate i'm very happy indeed :)
This buildlog has been amazing :D
Now I demand a final photoshoot with DSLR camera ;)
will definitely take some quality pictures once i've finished it :)... there is still the fan controller that i'm waiting for...
makes me happy when my work helps other people... good luck with your stryker mod :)
make sure to start a buildlog once you start working on it
Yeah I agree :)
Thanks in advance.
i'll upload some bios screenshots today or tomorrow :)
good luck with your chip... and have fun :)
cheers mate :)
my surename is white, so i always liked white things :)... paracord sleeving looks really nice and isnt that hard to do... good luck with the sleeving.
Yeah I agree :)
Thanks in advance.
sorry mate was very busy in the last couple of days, but finally got round to do it...here you go:
hope this helps you :)
another update
long time no see...
i've been really busy in the last few weeks, but now i've had a couple of days to work on the rig again. the fan controller arrived and so did the allen bolts. i replaced the plastic bolts on the sidepanel to nice looking allen bolts.
the bolts
all of them :)
the panel before
and after
and again
so thats that sorted...
next thing the fan controller...
thanks to Lauren coz thats where i've won it...
the box
inside
got it all out
the fan cables
the braid
the fan controller itself
the backside :)
took apart
the screen from top
i haven't got space in the 5.25 bays due to the three fans, so i decided to put it into the drawer...
the drawer
i first simply hot glued the front cover onto the drawer so i dont need to take it of all the time... now i just have to pull it out and the drawer come out with it...
then i cut out a few pieces... fucked it up a little, but never mind it'll work anyways
back view
the fan controller fitted...
next thing was a cover to clean it all up... it hasn't been painted yet. will do that at a later date...
the cover fitted
they will hopefully look the same after the cover has been painted
in the rig
and again
and again
nice and shiny touchscreen
I'm using the first channel for two front fans, the second channel for one front fan and the first top fan, the third channel is for the top h100i fans, the fourth channel for the bottom 100i fans, the fifth channel for the 140 exhaust fan and the sixth channel i use for my led strips
i'll make a second cover for the little front bit so the hot glue will be hidden
tell me what you think and thanks for watching...
