Finally buying a new case and PSU!
xriccix
Gonna be getting the CM Storm Trooper case for sure but cant decide between these 2 PSU's! Never gonna be a high end rig, never gonna have more than one GPU, prob never gonna be water cooled!
http://www.scan.co.uk/products/850w...ff-80-plus-bronze-sli-crossfire-eps-12v-quiet
or
http://www.aria.co.uk/Products/Comp...+Silver+Modular+Power+Supply+?productId=36021
Thanks in advance
depending on ur specs I'd say the HX750 will work great for you. 850 will most likely be overkill
yeah i figured as much, just that the 850 is cheaper and id like to save the money if i can, but if the 750 out weighs it that much id stump up for that
well if its cheaper then its a better deal price wise and leaves room for expansion if needed. The 850 is only bronze cert while the 750 is silver cert.imho 750 wins
