Finally built a desktop - "Ai" build
although some of the sexiness of the H440 might be lost when I modify the front and top covers. I want to go push/pull for both front and top rads, and there is not enough room inside, so there will have to be fans on the outside. I am hoping I can still make it look nice when it is done.
I am excited to see this build fully watercooled
me too ;)
so... I am getting the EK D5 Dual pump top, and I can get it bundled with 2 Alphacool VPP655 Variable Speed or 2 Swiftech MCP655 Variable Speed pumps. The Alphacool are a little cheaper because they are just the motor. The Swiftech comes with the original housing that you have to remove for the EK pump top. Second question: Should I get the Swiftech PWM pumps instead of any variable speed? The pumps will be in line serial.
Is there much of a historical difference or a site preference between the two? Price isn't that different. I am more interested in reliability of the pumps in question.
