Feronix
Well mine is a thicker rad - but my small pc is going to be a H100i.
So thicker do push-pull and wih the 100i what should I do -push or pull or?
Depends, usually it doesn't matter temps wise wether you use push or pull, but when you go with fans like Corsair SP or Silverstone AP fans I guess push would do slightly better as they are designed to push air through high density opjects.
Though, with pull it is easier to clean the dust out as it's on the rad, not between the rad and the fans.
This video explains it pretty well:
