Fan Upgrade... What to buy...
Ok, quick question...
I will be using some form of splitter that gets its power from the power supply rather than the MB and running 3 fans together from one fan header/bus. If I use 3wire/pin fans with a 3 to 4 adapter, will the fan software pick up the RPM of the fan?
No. If you hook it up to the PSU the OS will not read it in any way. Honestly i think you are far to keen on 4 pin. It's not really worth the hassle. It's best to get the fan you want and use a 7v reducer.
http://www.amazon.com/BITFENIX-Alchemy-Multisleeved-Adapter-BFA-MSC-M33F7VWK-RP/dp/B00IZFNP86
Something like this. Just hook the molex up to any spares ones you have then plug the fans into that 3 pin headers and they will all run at a constant 7v. Won't spin up or down and you don't have to worry about noise. 3 pin is the easiest route
I have found what I am looking for, 2 choices.
http://www.frozencpu.com/products/2..._RPM_NFA12IPPC30P.html?id=Iq3vv5TR&mv_pc=1297
http://www.frozencpu.com/products/1...0-1500_RPM_-_29_dBA.html?id=Iq3vv5TR&mv_pc=86
The splitter I was referring to is something like this...
http://www.frozencpu.com/products/2...ST.html?tl=g47c121s424&id=Iq3vv5TR&mv_pc=1771
rather have it in a smaller form but I can deal with it.Power from Power supply rather than motherboard.
Thanks to everyone for all the help and suggestions.. Special thanks to NeverBackDown, you have hung in there with me. Kept me on my toes.
Leaning heavily toward the Noctua.
Don't sweat it. I've been through far worse on here before. This ain't nothin lol
That splitter would work yes. I'd just stick with this fan:
Noctua NF-P14s redux 1500 PWM 140mm
You don't need 3k rpm fans for any reason lol.. plus these look better. I choose the 1500rpm version because since it's pwm it's best to have the widest range but if you want slower ones the 1200rpm would be a solid choice. Just means it won't ramp as high when given 12volts so it will always be quieter. Up to you when it comes to noise
The reviews I read said the redux fans were less than par with the Noctua fans, less airflow and louder. Kinda turned me off of them. But i have noticed that one review will show one thing and another show something different. Have you seen anything to the contrary?
Its a fan review.. it's really all subjective and no one has the same specific testing methodology nor do they have the proper equipment/setting to test noise/airflow/static pressure. You can really only go off by other people's experience and how they used the fan. Otherwise it's all subjective. Only thing i have seen done properly for fans, is using equipment that can regulate how much voltage can be supplied to fans and it gives an indication of more mechanical design/performance than the actual blades and motor generating noise/airflow/static pressure
