Fan speeds to max out a 45/50w fan controller
p1987
Hello,
I am looking for the quietest yet best looking fans and silent for a 45/50w fan controller. Static pressure is a must.
I'd like these fans to operate fast as I will be cooling a GPU.
Are there any fans out there that can be ramped up exceptionally high for speed to utlilize the 45/50w controller ? (per each fan connector). I would expect some noise.
Thanks for your help
I don't think i get the question. You want a fan that runs at 50W??? And why?
The Corsair ML120 or ML140 goes to 2000rpm+
Given that most fans are 12V and run at 0.05 - 0.09A you can work out how many Watts they give out.
12 (V) X 0.09 (A) = 1.08 (W)
The above is for Corsair SP120s so they are 1.08W each at full load.
