Alot of people seem to be moving away from SMP (CPU) folding in favour of GPU folding, and given the numbers you can see why. You don't have to fold on everything. As a general rule of thumb for each GPU you fold with, you need to leave 1 core of the CPU free. So once the CPU has finished folding its current WU, you could try and leave it off altogether & it may actually boost your PPD on the GPU.
Did you set the advanced flag for your GPU? Having done a bit of research you should be getting nearer 60K PPD with a 7870 if you set the advanced flag and get Core 17 WU's (8900's).Ah right, I currently have 7 cores on my cpu folding and I was wondering why it was saying 7 not 8.
Did you set the advanced flag for your GPU? Having done a bit of research you should be getting nearer 60K PPD with a 7870 if you set the advanced flag and get Core 17 WU's (8900's).![]()
2x 2697 V2's (12 cores/24threads each) and a couple of GPU's will be needing to be tested.......
I took that as top 100 or 1st page of the Redline leader board. it should happen relatively fast as there is already 20K+ points for the new folder and the top 100 is at 25K or so.
Very nice sheroo!!
Those 11 are the ones I've populated, but hopefully there'll be some other contributers soon.Also would the new contributer to F14R like to identify themselves as there is now 11 WUs completed:lol:
Core 17 is quite sensitive to OC and may take a little experimenting to achieve max stable OC. IIRC a good 7870 with proper OC should tickle 50K PPD
Would it be worth mentioning it on a vid or facebook?Why has this not been more popular! Ill be putting the OC3D monster rig to this while testing I think.....![]()
