jimma47
Hi guys. Just a quick one - I've started getting errors folding on my GPU. I haven't been folding continually so it's hard to pinpoint the exact cause. I can say it ran fine on Win10 previously. Since the Nov update I get the OpenCL.dll is missing error.
I reinstalled the client and all appeared to be fixed. Ran it again last night and the error reappeared.
It only happened on one card when it was starting a new work unit. It prevents the GPU from processing anything. The other GPU continues to process as normal. I haven't tried waiting for the second cards unit to finish however from my first experience they end up both crashing at the end of the unit. AFAIK the CPU continued processing fine. (I didn't specifically note the times of the crash to see whether the CPU had started a new work unit since)
It's almost like Windows is uninstalling a component in the background. I do have automatic updates switched on.
Has anyone else had this issue? When I get home I'll try a complete NVidia driver clean/reinstall and F@H as well.
If the issue continues I may have to turn off updates which is not really ideal.
Cheers
Cheers
