External water cool kits
barginbin
I want an exteranl water cooled system for my PC system its a TT amour with a Intel core 2 duo (LGA775 socket) and want to know how much money a kit to do this is? I have seen the Nautilus 500 kit but dont know what much of the spec means (doh!) i have also seen the Koolance kits but they seem very exspensive or is this a realistic ammount of money to water cool a CPU?
Thanks for any help :worship:
would stay away from the kits (eg Koolance). You should build a custom setup. You can mount a rad externally and have the pump res internally.
Ok Thanks i dont really know what bits i need or how they connect up.
I take it you need
Pump
Res(whats that lol)
Rad
Water blocks
Then things like tubing and connectors etc
Also when buying them bits what should i be looking for?
name='barginbin' said:
What sort of budget is realistic Jabski for this ?
I was thinking about £150-£200?
thats fine. Will have some change too. Are you just wanting to do the cpu ??
