Innocent159
Almost any motherboard that takes an Intel Pentium, also takes i7 CPUs. You're never going to need that much RAM before needing an entire system upgrade and why on earth would you want a motherboard that's SLI/CrossfireX capable if your PSU is not, and you're always better off with single card solutions, especially on a budget.
The only thing you'll want to make sure is on there is Sata III in case you want to add an SSD some time. Just get a cheaper 1155 motherboard, with the Ivy Bridge i3 that's on that site (cheaper than Haswell and barely any difference), a decent quality power supply, some cheap case, a big enough HDD, 4GB RAM minimum at 13333/1600MHz and spend the rest on a nice graphics card.
Thanks guy, will put something together and share with you for last thoughts before representing it to my dad
What would be the difference if i go with a matx gaming pc?
