ek-kit-h3o-supreme-lt-120
blair
http://www.scan.co.uk/products/ek-k...ntel-cpu-using-10mm-fitting-water-cooling-kit
Hi, the above WC kit how good is it compared to the XSPC 120 kit as i will have £46 credit with scan but i need a cooler and i was after a SSD so should i get this kit or should i spend the extra £50 and get the Agility 3 60GB ssd and save the £99 to get the XSPC RS120 kit from Specialtech.
This means i would have to do some saving and have to use the stock cooler for a while.
I would save some money and get at least xspc 750 rx240.
Boot time and overall smoothness,the ssd is more needed now.
And if you only are looking for a single rad,xspc 450 rx120,the rs120 is to small i think.
tom did a review on the rs120 and so did another forum user and i though the temps were good my antec 620 would keep my cpu under 60C so if its a lot better than a all in closed WC then it will be ok i would get a 240 rad but how would i mount a 240 in a cooler master enforcer.
