AlienALX
Well-known member
Finally done ! Specs. Rigs go from 1-3 from left to right.
Rig 1 - Dianoga.
2006 Alienware Area 51 ALX chassis
AMD 1055T OC 3.6ghz
Asus M3A32 MVP Deluxe Wifi
8gb (4x2) DDR2 800
Nvidia GTX 950 OC/1600mhz
Cougar CMD 620w PSU
Modded Killer NIC
60gb SSD/Win7
2 x 500gb laptop drives in roof
XSPC coolant (green)
Cooling.
XSPC dual bay res w/Laing DDC pump
XSPC hose 19mm
Chinese CPU & GPU WB
EKWB 360 rad front
EKWB 60cm 120 rad rear
Monsoon Chain gun and XSPC fittings.
XSPC temp sensor
Silverstone Air Penetrator fans (silver, green LED)
Numerous mods. Full log here.
https://forum.overclock3d.net/showthread.php?t=77742
Rig 2 - Riff Tamson
2008 Dell/Alienware Area 51 ALX
Intel Ivybridge Xeon 8c 16t @ 2ghz
Gigabyte X79 UD3 motherboard
Team Elite 2133mhz DDR3 (8gb, 2x4gb) With Arctic coolers
AMD Radeon Fury X
Asus Xonar DX
Corsair RM 750
OCZ Revodrive 128gb Win 10
5 x 500gb Pipleline
Cooling.
XSPC hose 19mm
Monsoon Chaingun fittings
Chinese pump
XSPC single bay res w/dual bay res cover
EK Supreme CPU block
XSPC temp sensor
XSPC coolant (red)
Noiseblocker bionic fans (white)
Watercool heatkiller 240
Numerous mods, link here.
https://forum.overclock3d.net/showthread.php?t=78513
Rig 3 - Rise Of The Triad
2014 Dell/Alienware chassis
Intel 5820k @ 4.6ghz
16 gb Crucial DDR4 @ 2133mhz (4x4gb) with XSPC coolers
Dell Alienware/ MSI X99 motherboard
Nvidia Titan X with EVGA Hydro cooler
Soundblaster Recon 3D
Soundblaster Xfi Titanium HD
Asus Xonar U1 (ext speakers)
Asus Xonar D2X
Asus RAIDR 480gb PCIE SSD
OCZ ARC 100 480gb SSD
Sandisk Ultra 240gb SSD
2tb WD green
600gb WD Velociraptor
Cooling.
EVGA Hydro cooler on CPU
Asetek 120mm AIO on CPU
Noiseblocker Bionic fans (blue)
Numerous mods, link here -
https://forum.overclock3d.net/showthread.php?t=72185
Pics.
Rig 1 - Dianoga.
AMD 1055T OC 3.6ghz
8gb (4x2) DDR2 800
Cougar CMD 620w PSU
Modded Killer NIC
60gb SSD/Win7
Cooling.
XSPC hose 19mm
EKWB 360 rad front
XSPC temp sensor
Rig 2 - Riff Tamson
AMD Radeon Fury X
Asus Xonar DX
Corsair RM 750
5 x 500gb Pipleline
Cooling.
XSPC hose 19mm
Chinese pump
XSPC temp sensor
XSPC coolant (red)
Asus Xonar D2X
2tb WD green
Cooling.
Pics.
