Hello, here is my overclock... has anybody got this combination at a higher overclock? If so what settings did they use and what cooler?
Stress
Idle
When stressing my processor with ORTHOS I get about 50-55C temperature using nvidia's system monitor.. In the BIOS temps I usually get is 40C idle.
Here are my components detailed as possible
OCZ Reapers 800Mhz 2GB Dual Channel Kit
Geil Value 800Mhz 2GB Dual Channel Kit
XFX Nvidia 680i LT Motherboard
OCZ Vanquisher CPU Cooler
160GB SATA1 Hard Drive
550W Branded PSU
Intel Core 2 Duo E6750
BFG 8800GT OC Edition
That is the most of my main parts that are needed for you!
The voltages that I used are as follows
CPU Core: 1.45V
CPU FSB: 1.5V
nForce SPP: 1.50V
I upped the FSB by 40Mhz each time and rebooting and seeing if I booted into windows, I got up to 3.3Ghz! I don't even know if I overclocked it right
The memory is not overclocked and has stock voltage, the memory and the processor FSB are unlinked!
- Bondi
Stress
Idle
550W Branded PSU
CPU Core: 1.45V
CPU FSB: 1.5V
nForce SPP: 1.50V
- Bondi
