WooZ
I am going to mod my Define R3 front to support two 140mm fans properly (now they are glued with hot glue )
And I am thinking how to filter those intakes I have three ideas:
1. Use two aluminium 140mm filters.
2. Use single foam filter (280mm x 140mm)
3. Use single cloth filter (280mm x 140mm)
Which would be better? I thing foam would be better choice but I doesn't have any experience with aluminium or foam filters.
For me in first place is dust proofnes then ease of clean and finally airflow.
I use Prolimatech Blue Vortex 14 fans and I have cat and two mouse's in my room and PC is siting on the table.
