Michaeljcox24
Bought a new board yesterday, Asus P8Z68-V Pro Gen 3, and ran into a problem during the build.
I have an aftermarket cooled GTX470, which has 4 bulky bolts that stick out of back of the PCB that fasten the heatsink down. When I put the card in the 1st PCI-Express slot, I cannot install a soundcard above it (Xonar d2X), because the bolts get in the way of the cards depth (xonar is about 10mm thick)
So I've had to put the card in the white slot (second one down) for the time being.
Will this make much real world difference to performance? Is there any way I can change in the bios the speed at this lane runs at, as I believe it's only x8?
How do other lads get round this who have this board and card? If there were no bolts on the back of the GPU I should imagine it would fit but would still be very very tight.
