N
nick25
Guest
Hi guys, I'm hoping you can help me out. One of my 120mm fans on my radiator is broken. It's as though the magnet isn't strong enough or something. You can push the fan (blade part) away from the motor part with your finger, you can also wobble it side to side with your finger. When I switch it on it just wobbles and so hits the sides as well as the radiator, eventually stopping.
Does anyone know if there is anything simple I can do to fix it? I REALLY don't want to take everything apart for the third time..
Thanks, Nick.
Thanks, Nick.
