Disaster
dave1920
Okay the shiznat has hit the fan. For about a week I haven't been able to see how I was losing so much liquid to evaporation, as the level in the resevoir has been decreasing. Originally when I was testing the system I thought I had spilt some water over the base of the compressor in the chiller, on this pic between and below the white electric box and the black compressor.
get.php
now of course it is obvious that the delivery damage included more than the chipped fascia on the titan 150.
Please has anyone any easy ideas to fix this thing.
The only thing I can think of is using sealant to 'flood' (haha) the base of the black compressor and hope it seals the leak without blocking the tubes?
Dave
Yeh but I wouldnt RMA it after all I've done to it. Funny thing is that bit I think is leaking is the only area I haven't gone near cause I haven't a clue about it.
Dave
Ill try and take a pic but my camera is in work at the minute and I keep forgetting to bring it home. Ill try and remember tomorrow but the black compressor bit is fixed into the base of the chiller by 4 points. The point on the corner which has the electric box, white box, is were I originally saw the drops. So it wasn't leaking onto the electrics but it is damn close. Also the whole thing is kinda mounted now in my huge case which I had to destroy to check the thing so taking pics may be tricky. Thanks for the replies guys and ill post some pics tomorrow.
Dave
Heres the leak
get.php
There has also been a lot of water around the point where the earth wire is bolted, and yes I know that is bad. I think the water is coming from the point under the red painted bolt on the left and I think it is getting worse.
Help PLEASE!!
Dave
