Dialectric grease
equilibrium
Hey all,
Bit of advice needed... I once ownes a vapochill and used Dialectric grease in the socket. The cpu i used still has it on the pins and as i dont use phase id like to remove it? Whats the best method ie;tools....
Help would be appreciated
Thanks
DAve
A lot of people here use electrical contact cleaner - you buy it from places like RS components or Farnell - expect to use a whole can though.
Cheers
Mav
Cheers MAv, I dont know what RS components or Farnell is i live on a little island which is 3miles by 2 and a 1/2 lol. But ill see if i can get some on the net. Appreciate your help Mav ;)
Dave
For future reference for anyone wondering, pure alcohol, meths and white spirit also work well.
Tools to use are: kitchen towl, small container for swilling pins of CPU in, soft brush (old toothbrushes work great), and some patience.
G
Where can we get pure alcohol from - I am not keen on using meths/or white spirit as it can leave a trace behind (can't it?)
Also nail polish remover is usually acetone base - Won't that react with the socket or lacquer on the board itself?
Mav
Thanks to all for your replys and info! This is good for future reference. You never know maybe someday ill look at purchasing one of Phils mach II Gts :)
DAve
